B&S burning a lot of oil - most probable cause?
Tobi09
I think this is a good idea. To your experience, running an engine with a lot of gas mixed in the oil for a few hours does not necessarily lead to completely worn out piston rings (due to loss of lubrication the gas causes) ?
Walt said:
The following is an example of interpreting date Code 99011556:
The first two digits (99) denote the year of manufacture. In this case it is 1999.
Ok, let's apply that to my code numbers in question:
Code No. of the engine: 9604014A
So my engine was built in 1996
Used Before Code Date of the rings is 01041900
Which means 2001. Since my engine was built before 2001, I need the old rings with part no. 495854. Since this is the same (according to some stores) as 499996, I can also use these? But why are they sold separately then by B&S and why is there such a price difference?
https://www.amazon.com/Briggs-Stratton-499996-Standard-Piston/dp/B000K1YFI2
https://www.amazon.com/Briggs-Stratton-495854-Standard-Piston/dp/B0038U3MJ0
Not planning to order rings right away, just in case I will need them.
Those ring sets should not be interchanged. The old set (495854) is for an L-head engine and the new set (499996) is for an OHV engine.
Tinkerer200
Some early OHV 28 series engines took the same rings as "L" head 28 series engines. His code number will tell the story.
Walt Conner
Tobi09
Just to let you know: the head gasket was blown. Replacing it solved the problem completely, so the piston rings seem intact. Thanks to all participants of this thread.
turbofiat124
I accidentally added too much oil my 21HP B&S Intek engine last fall. I did a quick check on the internet and added 60 ounces instead of 48 ounces based on this chart:
http://www4.briggsandstratton.com/miscPDFs/oil_capacity_chart.pdf
It didn't take long before I blew a head gasket:
http://s222.photobucket.com/user/turbofiat/library/craftsman mower?sort=2&page=1
The mower was OK as long as I was mowing on flat ground but started mowing sideways on a hill, all of a sudden the engine started smoking really bad and started making that "death rattle". I managed to restart the engine but it was never right after that.
It didn't seem to really smoke until I started going up a slight incline.
I wanted to put off fixing the engine after the end of the leaf mulching season but because the spark plug fouled and the oil was turning black as coal, I figured it might be buying a new engine before it was all over so I decided to go ahead and replace the head gasket.
The bad thing is before this happened, the mower didn't use any oil but now it smokes on startup for about 5 seconds if it's been sitting for a couple of weeks and I had to add about 1/2 quart the other day (maybe after 15 hours after replacing the head gasket). Which is really not that bad but the engine only has about 200 hours on it. I guess as long as it's not fouling the spark plug, I'm not going to worry about it.
