reynoldston
I remember leaded gas as most of us older gentlemen would.
Lasted until the 80's. I remember the exhaust pipe turning gray inside after a long trip.
Seeing you remember the change over from leaded to non-leaded you must also remember the older cars you had to add a additive to the gasoline because the non-leaded ran hotter and the valves would burn on the pre-1980s if you didn't.
