jeckel7234
Hi all,
I have a B&S 42A777-E1 18.5hp motor on my riding tractor. This motor has a diaphragm style fuel pump that is integrated into the body of the carb, Ive had massive issues with the ability of this pump to pull a vacuum on the fuel tank.
Every 2-3 mows, (during the season 2-3 weeks) i have to rebuild the fuel pump, most of the time i really can just pull the springs and diaphragm out and reinstall to get the motor to work. As i go to crank over the mower I notice that fuel is not flowing through the fuel filter as well as ive verified little to no suction where the fuel line connects to the fuel pump.
I took the springs out of the fuel pump and bought a low pressure/low flow fuel pump off ebay with the hopes that i could bypass the diaphragm pump. I could the motor to start but not stay running for longer that a few seconds.
Does anyone have any suggestions or ideas for a more permanent fix?
Thanks,
Thanks,
