The engine is on an Ariens 936042. The tractor had sat for a while and when a friend bought his house the old owner threw in the tractor and said it had been running. It initially would not start with a new battery and going threw it a few electrical problems were found and repaired as well as replacing the fuel pump, filters and carb. I adjusted the valves and governor. It will now start but only with starting fluid. After the first cold start with starter fluid it will restart without starter fluid. Engine is good under load and appears a constant so the governor is working. I’m thinking the choke is out but as simple as it would seem, and without a manual, have resorted to online video clips that haven’t hit on where this is adjusted other than moving the throttle cable a bit. My question is - is there any other point of adjustment or how is this properly done?
