[EDITED] Sorry, meant B&S 375. not 350.
Hey guys,
I have a B&S 375 mower which is having an issue with starting. Ill pull the cord and it appears really hard or it gets to a point during the pull where it stops/becomes hard to pull (but not impossible)
story:
- Purchased mower
- Got home, looked at mower, started mower, mower ran (poorly), decides to clean mower (carbs particularly)
- Notices rest of mower is filthy, decides to clean more than just carbs
- I remove base/plate from mower (which has blades attached to it)
- Unbolt engine from base and remove (3x bolts)
- I remove Starter/rewind assembly, fuel tank, carb, Armature-Magneto, muffler (already damaged)
- Drain old oil (through oil input hole, I couldn't open drain plug)
- Clean parts thoroughly
- Re-assemble everything
**2x issues**
1. Won't prime. Bulb tries to suck, put wont squirt into intake, I 'think' it could be an issue with the seat-check-valve(?)
- Removed seat-check-valve little rubber seat inlet thing + bearing + spring. Putting my finger over seta check valve hole in carb Im able to fill the bulb, remove finger and can squirt into intake.
2. Pull starter cord, gets to a point then it becomes hard to pull (put pullable)
- Removed/tested starter/rewind assembly, pulls/retracts ok, can't see any issues there
- Turn flywheel by hand, gets to point and tough to turn.
- Removed spark plug, can pull easy.
From what I can tell, it may have something to do with compression?
I jumped online and read something about Hydro-locked, thought this may be it as I did have the engine on the bench and may have tilted it. I tried starting multiple time with spark plug removed, didnt see any excess oil spray out
- put spark plug back in, still tough to pull start
My mind is totally boggled right now.. I have no idea what's happening Any suggestions ?
p.s. I'm probably not the best at explaining things, but if you guys want me to make a video, I can whip out my phone and shoot a few minutes.
Thanks
Hey guys,
story:
- Purchased mower
**2x issues**
Thanks
