Thanks, it worked! Just wondering - by pushing the rubber priming bulb, how is the fuel sprayed i.e. push bulb - pressure reduces, gas from tank gets sprayed. Intuitively, by pressing the bulb, shouldn't the pressure incresae momentarily?Carb on tank....the gasket goes on bottom of plastic carb first, then the diaphragm. The diaphragm is against the metal tank.
