- Sep 24, 2017
- 288
- 6,901
My kawasaki Mule uses a vacuum pump, i have the clear line on it and it works great.
Polyuerthane
Polyuerthane
yep, as I said that in some previous posts, I thought about that at one point. But the oil isn't being thinned down, don't see or smell any fuel in the oil either.I had two mowers that had oil coming back to the carburator and in each the float valve was stuck and the gas was filling the crankcase and forcing the oil out.
Reading the posts, couldn't find any reference to the having done a compression test. When the new rings were put in, did the cylinder show scoring? As someone suggested, I would hook up spark tester and run it. Look for any signs of missing or poor ignition. Also, I would check for oil breather for blockage or sludge.
As I said in previous posts, my Dad bought this mower from his nephew who bought it from an auction.... We ran it for a couple seasons, but there always seemed to be something I had to fix all the time to keep it running. Fast forward, I basically have rebuilt the entire mower. Including a complete full engine rebuild, hasn't been run maybe an hour.So your engine crankcase is getting pressure inside it from somewhere. As oil is splashed around inside, that increase in pressure is pushing oil through the breather line that goes to your fuel pump. So, where can the pressure come from? Well, as the piston moves up and down, it creates positive and negative pressures in there. This is usually relatively low pressure differences because the size of the crankcase and the distance of the piston motion. Any oil usually goes through breather and back into engine through galley.
So, in your case, I'm guessing as the piston goes to top of stroke to compress fuel/air mixture (or exhaust stroke as well), and some of that is getting by and pressurizing the crankcase - loss of power also. If that engine has a oil filler tube, you may feel the blow-by. How does it get past? Either the, as you said, the head gasket, valves not closing, or the rings. Harbor Freight has a cheap cylinder pressure tester. I dunno the specs but seems 90 to 120ish psi should be good.
I'd do a leak down test next.
Good luck
Did we do a leak-down on this?
Yep, what StarTech said above, Can't do a compression test on this engine, as it has a compression release built into the camshaft to make it easier to start. That compression release doesn't move out of the way until centrifugal force overcomes it when the engine is running. So using a compression tester only gives a false reading at best.The problem is these engines have an ACR which limits the compression to 60-90 psi. In order to get a valid compression reading ti would require adjust the vavle clearance until the ACR is no longer effective. But there is one problem that as the electric starters are too weak to turn the engine through the compression stroke. Briggs recommends doing leak down tests instead when a compression problem is suspected.
humm...I'm pretty sure there's a Reed valve under the flywheel that goes bad and that's why you have oil in the vacuum tube.
The clear fuel line you are using going to the fuel pump might be some of your problem! This line will collapse and therefore won't work for the fuel pump correctly! That fuel line should be a ridged black double core rubber line. If it collapses it will not operate the fuel pump correctly!
Snowmobiles use the same type of fuel pump and they will not work correctly with the clear fuel line either.
The fuel line I am talking about comes off the Engine. It is the pulse line to the pump. This must be dual core rubber line. The other lines can be clear line
I think he said in the original post that the head gasket and breather were both replaced.HOLY COW. I am surprised by the responses.
I run a repair shop, and am a Briggs master technician. you are describing a typical problem. so typical, i could not believe the responses. you have too much crankcase pressure. normally, at a shop, we hook up a crankcase pressure gauge at the dip stick to see what the pressure is. the tool is called a manometer. the crankcase needs to show negative pressure (a vacuum) and, you are describing all of the typical symptoms of positive pressure. there are a few things that cause that, but the most likely suspect is a blown head gasket. second would be a breather valve that's not working, and third would be blow by past the rings, but that's the most rare.
BTW, i have worked on perhaps 1000 machines in the last year.
the crank case is building up pressure, and forcing oil out of all sorts of places. if i was a betting type, I'd bet its a head gasket.
