BobJohnDeere
Need some advice.
I have a B&S 18.5 OHV on a Z225 zero turn. Long story short it died - and when I removed the valve cover one of the valve caps was missing. I assume both valves have a cap since the one that was missing had a huge gap. The reason the cap likely fell off was the valve rocker stud had started to come lose and backed out enough that the cap fell off. I could not find the valve cap. I looked behind the rod cover and it still wasn't there. Way in the back there looks like enough room that the cap could have gone into the engine.
Question: Has anybody had the same experience that cap fell off and made its way into the engine ? I would have remembered if it fell out when I removed the valve cover - so if the second cap was there its somewhere in the engine.
Any tips on where to look for the missing cap ? or whether it can stay in the engine (likely at the bottom of the engine in the oil reservoir) ?
Any advice would be appreciated.
The engine is - 31P707-0123-E1
The valve cap is - B&S 691843
