Slowly making progress. Used a small brush and a shop vac today to get a lot of the crud off (there was a lot more than I anticipated once I got started). Still have a little more to do and then will probably hit it with some simple green and a hose to see if I can get a little off and if I can get some of the crud I cant reach by hand or with the brush (inside the cylinder shroud, etc).
