Hi, I have a Poulan Pro riding mower from Home Depot that is practically brand new (about 3 months). We took the deck off, and use it to tow 4,000 lb cars around the parking lot. This is replacing a John Deere D100 that we used for 4 years with no issues, until it failed.
Engine: B&S 17.5 31R907
Here's my problem, it starts fine and idles smooth. About 1/2 throttle and up, it pops out of the exhaust like a misfire. It may have been doing this from day 1, if not, it started in the first week. When I watch the butterfly valve on the carburetor, the governor allows it to flutter rapidly, up to the point of briefly closing the valve. When I hold the butterfly valve open, it runs smooth. I tried slightly increasing the tension on the governor, with no luck (I put it back in stock position). Can this be a problem with the governor internally, incorrect valve adjustment, or carburetor? We use only good 93 octane fuel, and it's used almost every day.
Any advise is greatly appreciated.
