- May 6, 2010
- 12,021
If you still have the spark plug in that 1/2 revolution would be the compression stroke, and will be quite difficult to turn by hand if everything is working properly. Removing the plug will make it easier to turn through that area. If the plug is out when doing this sounds like there could still be something hanging up.
