David Nash
- May 4, 2017
- 6
Got the manual and thanks for the advice guys.
I'll let you know how I make out once I replace the filter and pump.
David
Well the new filter and pump are installed and I changed the oil.
Gas is still coming out of the new pump and the oil is at the right level.
I do not smell gas on the dip stick however there is smoke coming out of the oil reservoir whenever I remove the dip stick.
The fuel lines are the same as they have always been before this problem started.
What next?
