B&S 12 hp
Hal12
Have a b&s 12 hp on an old dixon...1990. Occasionally gas will get into the oil in the crankcase. Shutting off the
gas from the tank when not in use helps. What causes this? tia
DaveTN
Most of the time I've found it to be a leaking needle and seat.
Not enough pressure to keep the needle on the seat etc. fuel
by passes the needle and seat in the carburetor.
Hal12
Put a new carb kit in a few years ago. Just got it back from the shop where I'm sure they didn't
shut off the fuel for the month it sat there. They supposedly cleaned the carb and gas tank.
It had started losing power after about 1/2 hour of cutting. Bought a cheapy 20$ carb and put
it on. Ran like no ones business for about 1/2 hr, then started losing power. Mechanic says the
carb wasn't right. For a newer engine. I didn't want to spend the 130$ for another carb..walbro
and so when I got it back it was still cutting out. Put the original carb back on, which I had
cleaned up and it now runs great. Think cleaning the gas tank helped.
