automatic compression release, KS590-3020
Doc8404
So it can stay on the mower?
If you are going to do it on the frame then remove the belts so they are not pulling on the crankshaft which will cause alignment problems on re-assembly. Just hope you are good at jigsaw puzzles.
As Star says
I do buckets in the mower belts removed .
A very quick job even more so because all the bolts face up so are easy to get at and all of them take a 10mm wrench / socket.
Doc8404
why?
how so?
Warranty work so I am not working on it anymore.
