My 94 MT has trouble climbing hills. Regular turf tires just spin. I know walker has some all terrain tires; but they are wider then what are on it. I put enough divits in my lawn turning around, so I'd like to stick with the same width (18X7-8s). I see some ATV tires that are the right size. Anyone ever try this? Or does anyone know a reason they can't be used? ) ie: sidewall rubs on frame. Seems like it should work fine, but I've been wrong before.
I'm assuming that wider tires will tear up more turf on my turns, thus my reason to stay with the same width tire
