Arm Shivers after Trimming My Lawn
panabiker
This is not really a lawn care question, but I figured you guys are more experienced to know. Lately, every time I use a edge trimmer to trim my lawn, My arm shivers for about an hour afterwards, and I feel weakness in the arm. This is only for about 30 minutes of trimming, using a relatively light weight electric trimmer. Anyone else have the same issue? I can't imagine if I do it as a business. Does it indicate some underlying health problems?
It is called thrombosis because your muscles are not as strong as they used to be
Two solutions
1) Get a set of weights and use them
2) fit some foam to the handle or wear some anti-vibration gloves ( as worn by jack hammer operators )
Better still both
panabiker
Thanks. I can feel better. Will do some weight training, not just for lawn work but for overall well-being of a man in mid-60.
amendez9091
I’ve started having this at the tender age of 23 when my mechanic career took flight.
It won’t get better so do what you need to when you need too.
