My model is 331777 type 2372 G5. I found the specs in my owner's manual: Exhaust .005-.007", Intake .003-.006". Valve cover removed, when I back the engine up to the back of the compression stroke, the lower valve is relaxed. I assume this would be the intake valve, since the exhaust valve should be active at this point. If I rotate the engine to the front side of the compression stroke, the upper valve relaxes, which I assume is the exhaust valve, since the intake valve should be active here. In their relaxed positions, I have adjusted each to the smaller gap of the spec range, to allow for wear to slightly enlarge the gap over time. The starter still will not take the engine past the compression stroke. I have not run the engine since adjusting the valves; I've only tested to see if the starter will fully turn it over at this point. Obviously I'm still missing something, but the question also has occurred to me: Why isn't it just designed with a strong enough starter to take it past the compression stroke without compression relief?
Mike
Ok,
now you come to the stop, look & listen bit.
Sit in front of your mower with the plug back in the engine and slowly rotate it by hand watching the valves move and listening to the gasses moving around.
you should be able to hear the engine suck in the fuel then feel the engine tighten up as you come towards TDC then slacken a little and you should be able to hear the comprssed casses escaping, sounds like a deep sigh.
Contine to rotate the engine it should go hard again as the remaining fuel is compressed then almost spin itself when it is on the power stroke then feel the resistance caused by the exhaust valve opening. Do this for a dozen or so times till you get the feel of what is going on. You should be able to feel resistance as the valve springs compress, you should feel no resistance as the valve springs relax & push the cam away
This bonding with your engine happens best on a full moon night facing the north naked :laughing::laughing:
Now if you are not getting compression release then you can tighten up the clearence on the exhaust valve a little more but if you get down to .004" and still do not have effective compression release then there is wear beyond the servicable limit in your engine.
Usually the cam will be worn out and will need to be replaced along with the cam followers, these should always be replaced as a set.
Sometines , particularly if the engine has been alllowed to run low on oil, been run for extended periods with oil that is too heavy or too dirty then the cam shaft bush ( hole in the cases most times ) can also be worn oval.
Watch the mvement of the valves they should move smoothly in & out if one moves with a jerky motion then the valve will need attention as a binding valve stem can also stop the starter motor dead in it's tracks but your problem is usually a lack of compression release
