OK I'll admit I don't know to much about mowers but last night I decided to try to sharpen the blade myself. I took that middle bolt out thinking it was holding the blade on. I just snugged it back up when I realized it wasn't. Today my gf was going to mow while I was at work before it rained. She told me it started right up on the 1st pull but then kind of made a jarring sound. Then when she tried to engage the blade it died. Now it's like it's seized up. You can not pull the cord.
Did not setting that bolt to a correct torque ruin the clutch? I did tilt the mower backwards for about 5 or so minutes to get the blade off. I'd always heard it not good for them to be tilted over (I've since learned I should of tilted onto it side) but could that of ruined the engine? I found a few videos about clutches but none of them seem to look the same as this one. I'm not sure if I should try to take it apart more or take it somewhere lol. I do most of the maintenance on my Jeep but I feel clueless.
Thanks in advance for any information anyone can give me.
