Tiger Small Engine
 - Dec 7, 2022
- Threads
 - 3
 - 1,606
How many hours on meter if equipped? What year is mower? Have you ever changed the hydro oil and filters?
If you remove charge pump cover, you will have to drain most of the oil. There is an O-ring that seals the cover. Unless it is really leaking, I wouldn’t worry about it. Sounds like hydrostatic transaxle internal parts may be worn and causing weak reverse movement. You would not know unless you remove entire transaxle and open it up (big job).
