SJMaye
The right Hydro-Gear ZT3100 drive has become weak in reverse. The tag on the drive is below
I thought to check the hydraulic fluid reservoir (which supplies both left and right drives) and found it empty. This sort of perplexed me because other than the right side weak in reverse the unit performed fine. I filled the reservoir to the level for cold and performed the air purge. I pulled the bars used to disengage the drives, started the mower, and began performing the purge. Everything I had seen on this said the wheels would not turn when the drives were disengaged, but my tires turned. Not just a slow turn, but as if they were still connected. I thought I may have done something wrong.
Even after performing the purge routine several times the right side reverse is still very weak. Can someone tell me what I did wrong?
