Well the first time I took the rectifier off I did not see any strap or any sort of ground connection. I've been looking ever since your first reply for a broken ground connection and haven't been able to find one.
I looked at the engine service manual and found an ignition diagram that doesn't say anything about a ground from the rectifier. I've attached the picture I was looking at from the Kohler service manual. I"ll go back out later and look for a broken strap.
Not sure where to go from here. The purple wire from the rectifier goes into a connector with many other wires. Not sure I should be ripping and tearing into that. I will probably make it worse. (See next paragraph) Should I try to replace the rectifier? Should I Just make up a ground jumper and attach it from the rectifier mount hole to another ground somewhere?
On another note, I managed to snap the flywheel bolt last week with my impact wrench because it had came loose after I hand tightened it when I reassembled it. I gave up and took it to a dealer and asked him to fix that and look at the charging system. When I picked it back up he said "It seemed to be charging, but it may be the rectifier. That is always the first thing to go bad". I didn't get a good feeling that he knew much about the charging system so I just picked it up and hoping I could get it figured out.
