Ariens M#936037 Reverse problem
tcd333
I just acquired the above mower.The gear shift lever is in the reverse position but the transmission is in neutral. Also it will only go to the 5th gear position. I assume it then in 6th gear.
Is this just a simple linkage adjustment or what???
Thanks for any help.
Tom
tcd333@gmail.com
I found a youtube video with the solution to my problem. Here's the link for any one else who may need it.
https://www.youtube.com/watch?v=M1kixYq2ZSE
Could be a linkage adjustment or could also mean the somebody bumped the shift lever on something and bent the shift lever itself.
Catherine
LawnWorld Support
Staff member
:welcome:
Welcome to the forum!
This thread has been moved over to our Ariens section.
