I need help. I have an Ariens 20 horse 46" riding mower from 2012. It's ran like a champ ever since I bought it new. Now, I started it up, pulled out of the garage and it died while I was driving it out of the garage and off the driveway and will not start back up.
Mower info:
Ariens: A20H46
Product: 93605300
Model: 96046002300
Engine: Briggs and Stratton Intek with XRD 540cc -> 331777-1372-B1
Things I've done since it died.
Mower info:
Ariens: A20H46
Product: 93605300
Model: 96046002300
- Put a new spark plug in it. [(Calls for Champion# RC12YC - obsolete) compatible NGK - BKR5E. 7938 is what I used.] I also found and bought Briggs & Stratton 5092 PN: 496018S.
- Changed the oil and filter. (Briggs & Stratton oil PN: 100028, filter calls for B&S 492932 - obsolete, I used B&S PN: 842921.)
- Checked the fuel solenoid (it is working).
- Pulled the fuel line off of the carburetor. Fuel is going through the fuel filter and getting to the carburetor.
- Sprayed a little starter fluid into the carb air inlet. Where the air filter attaches to.
- Checked for spark. Getting spark to the plug.
- I don't have a compression tester, but the engine sounds to be getting compression when it turns over. Sounds normal. When I turn the flywheel by hand, I can feel the compression. Hard to turn, then more loose, then hard again, etc.
- I don't see any frayed wires.
