Ariens 1440 EZR Zero turn
Bingo
I'm new here. I have an Ariens 1440 EZR zero turn. Something got under it and broke the cooling fan on the left hydraulic drive. I cannot find a replacement pully and fan for it. It is an Eaton drive motor, and I was told it was used on Gravely, Husqvarna and John Deer. Can anyone give me some information on this motor as the Ariens numbers are obsolete (Not Available). If I can look it up under another tractor company and model, I may have more luck finding what I need. Numbers 52&53 Thanks for your help! Arens part no.01528300 and 01528400Ariens fan.pngur help!
Bingo
Found a little more info. It was built about 2000 and it is an Ariens 915004
Skippydiesel
If no longer available, try modifying a fan off an electric motor. Be sure, fan blade pitch / air flow is correct for your application
Bingo
Thanks Kbowley, but that is just the fan. The real problem is the pulley. The fan I need is 6 inch 10 fin and yes, I did find one for about $15 Again, Thanks.
