Well........no, I didn't research it aside from many users on this and other forums discussing it. And when I saw that in my Gravely Owner manual I just figured that Gravely didn't "pull it out of their hat". I didn't say "Certain cutting conditions", they did. I'm not going to visit my best friend(Google:0), but I will contact Ariens Customer Support and ask them if they can add some clarity to the "Certain cutting conditions" and report back what they say. I will also ask them to confirm/deny that this(heeling the deck) adds a slight striping effect to the cut, although I already know enough about plane geometry to figure that one out:0)
I'm pretty certain that several of the professionals on this forum(user Carscw comes to mind) recommend heeling the deck so at least some contractors know about doing this.
I don't think anyone would complain about having some mild stripes on their lawn as many commercial ZTR's do this naturally because of their deck design so people see it on lawns cut but contractors all the time and it is becoming more and more popular.
I understand that you were quoting from the gravely manual, I would just like to know what the "certain conditions" are. It would be great if you could find that out! I wouldnt mind betting it has something to do with mulching but thats only a guess. If mower manufacturers really wanted us to heel the deck, they would come like that from the factory!
Heeling the deck may add more to the striping look but as I said, the stripe should be secondary to the cut. I also understand that the grass will, or at least some of it be cut twice. ie, front and back but, what happens between the blades. I would hazard a guess and say you'll increase the risk of a tear rather than a cut, deck build up, choking, clumping etc.
But think about it, if grass is getting cut at the back of the deck, where do those clippings go? They will circulate around each chamber, get sent from the discharge side to the trim side. It already happens with a normal deck setting but if lower in back, its going to add to it. Clippings will be chopped up more which can be a good thing but if there is moisture, you will most likely get a mash and more deck build up which create more problems.
There are thousands upon thousands of lawn cutters out there. I'd bet the amount of guys that heel the deck would be barely registrable as a percentage.
As far as needing a commercial deck to create stripes, or get better ones, thats not necessarily true. Ive seen stripes from JD lawn tractors that are up there with the best of them!
To heel a deck just for a little more stripe seems well, crazy to me! Stick a roller or rubber flap on the back of the deck if its important to you! Remember, some grass types just stripe better also, even some commercial decks stripe better than others.
I went searching on the subject on this forum and came across this
SandburRanch,
You touched on what was going to be my "follow-up" question(be careful........reading minds like mine can be dangerous:0)
Does the front-lower pitch and rear-lower pitch have significantly different clipping discharge efficiency???
In other words, with my deck set by the dealer at delivery with the front of the blades 1/8 inch lower than the back this has resulted in VERY efficient grass clipping discharge(without any trace of "piles of grass clippings" even without a "mulch kit")......AND......absolutely no grass clipping/dirt "buildup" underneath the deck that requires cleaning the deck belly before the next mowing. If I changed the blade pitch with the back side tip of the blades lower than the front and the cut of my yard looked significantly "smoother"......BUT.....there were heaps of grass clippings all over the yard and/OR a buildup underneath the deck that required scraping or washing out before mowing again this would NOT be a good trade-off in my opinion. I would rather have a less "pro-cut" look to my lawn than to have to deal with piles of grass clippings in the yard or cleaning underneath the deck after each mowing(something I do NOT miss about my lawn tractor with the 54" stamped deck:0)
Seems to me you were perfectly happy with the way it cut, or should of been! I cant figure out if you tried with the "heeled" setting or not so, did you? And is what you wrote here what happened? If so, its basically describing what I would expect!
From my research on here, seems you bring up "heeling" quite often. Have you actually done it yourself yet?
