There is no such thing as a "fully sealed bearing" apart from custom bearings made for specific tasks and you will not find any of them on a lawnmower $$$$$$
A RS ( Rubber Sealed ) bearing has a GREASE SHIELD to prevent grease getting out easily but as the lip has no strengthening spring it is pretty poor at the job
A ZZ bearing has debris guards on the bearing to prevent gunk getting into the bearing and they are meant to be fitted into a housing that has grease in it so as you add more it forces the old grease out.
These may have a second seal outside the bearing to prevent water getting in .
Interesting chart but totally irrelevant unless they specify the bearing manufacturer and the grease used and more importantly the suspension medium used for the grease
It also ignores temperature which will break down the grease faster
Most bearings from China come with transport grease which is very similar to assembly lube and just there to stop the surfaces rusting before you buy the bearings
And yes you can put too much grease into a sealed bering but it is a lot harder to do with a ZZ because excess will simply exude from the hole in the shield during use which is why I use ZZ where ever possible to replace RS because RS bearing are just too much trouble & require too much work fitting .
And if you has stopped to think about it for a second or two why would any mechanic go to the effort of popping a seal washing out the old grease & replacing it with better quality grease if they could just wack in a untouched bearing for the same price .
We do it for a reason and the reason is we do not want the customer back each & every season with stuffed spindle bearings
So caster fork bearings be they radial or tapered rollers get high tack grease so it does not all end up on the bottom with no grease on the top
I use a Lithium Soap grease with Molly usually a 3 grade
The wheels get a low tack Lithium soap grease usually 2 grade
Blade spindles get a high temperature EP lithium grease again grade 2
I am about to go over to a lanolin grease for casters which is low melt
All are marine grade greases because mowers get exposed to a lot of weather
I have just added a Ferris IS600 to the servicing fleet and they specify a Calcium Solfonate grease for the casters & the yokes so I am debating if I really need to add yet another type of grease as I stock 7 at the moment or if I should just wash out all of the Calcium grease & use the std Lithium .
OIls ain't oils Sol
Greases ain't just grease
OIls ain't oils Sol
