Any ideas on why a crank seal would be leaking after replacing twice
stang8689
  • / Any ideas on why a crank seal would be leaking after replacing twice
Well i don't have any bad news to report, I mowed the lawn yesterday, it had even more power and was faster. Today after work I came home and looked real good and can't see any signs on any oil leaking. So maybe I got lucky and fixed it but I'm still holding my breath. I wont really know until I use it a few times to know for sure but I am very happy at the current results. Thank you so much Rivets for all your help and I will keep you posted.
benski
Super! I hope it holds in there for you!:thumbsup::biggrin:
I told you to stay positive, I've been through this too many times and over 90% work out the first time if you go slow and don't skip steps. Not a bad job for a Ford guy, even they get lucky once in a while. Congratulations.
stang8689
Thank you so much for all your help I wouldn't of been able to do it without you, everyone on this forum really appreciates all the time you take to help others and pass on your knowledge. I wanted to fix it for you almost as much as myself.
stang8689
Just an update, I cut the grass again a few days ago and still no signs of leaks, the mower runs and works perfect, I have not done any more compression test because it seems fine and don't want any bad news. So thanks again to Rivets you saved me big time.
Glad to help out.
