ferrisbestyet
- Jan 30, 2015
- 1
- 39
Remember guys ,if you don't know,,, To all ways use anti seize on your,, lug nuts blade bolts spark plugs happy cutting
There are special kinds of anti-seize made exactly for plugs (that don't actually change the heat range) and I like all the input and no this thread is not stupid. You can ask plenty of people that have experience building engines and all of their opinions on anti-seize will vary.Yes and No Don't agree with the spark plugs at all, the others OK.
Like I said before though, I never had a problem not using anti-seize with this motto Use it don't over. Abuse it,,,
I just suggested (mainly) anti seize for the bolts holding the blades on,,,, Home owners seem to have a problem removing old blades as they become seized after many hrs of wet grass working on them ,,,,,, I use the Blue Loctite,, Not the Red for a lube and good holding power,,,Hope ,we helped the average home handy man mechanic ,,, My arsh loves my Ferris (smile),thanks h a n dI have to say I never heard of it. I have always put spark plugs and blade nuts in dry/clean and tighten them with a torque wrench. Just something new to me, but never too old to learn??? I have always used anti-seize where I will have a rust problem like wheel hubs. What I have used but not on spark plugs is Loctite. Loctite is a good lube and sealant for bolts and nuts.
OOOOOOOOOOOO ,, You are so right,, If they only knew,,,The ride with the spring loaded shocks,,, The removable floor pan....... The front deck design to throw the grass faster and cleaner than a flat nose deck.... I am a mechanic ....This mower really impressed me the first time I saw one,,,,,,,,Powder coated,,,,, top and bottom.......Made in the U S A ,I don't brag on much,,,,, But. I will here,,,,,, This is a hell of a nice (very well made)mower..... thanks Glad to meet you,,,, frank Shreveport la 74 old iron arsh (smile)We sure think alike then it comes to a Ferris. It was a little on the pricy side when I bought it, but well worth it.
