Kneale Brownson
 - Aug 9, 2021
- Threads
 - 3
 - 14
My new-to-me old Grasshopper 616 would not start after I blew most of the grass off outside my garage.  Pushed it inside and have spent a fair amount of time trying to figure it out.  First I found the 30-amp fuse had its legs corroded off stuck inside the fuse box terminals, so I got that all uncovered and discovered three red wires hanging loose.  After removing the fuse box and digging out the two corroded terminals on the 30-amp part, I identified the wires as the hot one from the solenoid, the one from the switch and the one to the regulator whatever that is.  I got new terminals, hooked the hot and the switch wires together on the top terminal, as on the wiring diagram. and the other to the other half of the 30-amp block.  The other three fuses were OK.  So when I turn the switch to start, power goes to the start fuse terminals, but nothing happens.  Previous Owner said he'd just replaced the solenoid, so I assumed it's still OK.  I suppose I should remove it and test it.  How would I test the starter itself?
By the way, I've learned that there are two little bent arms coming off the drives that will twist and mount into two holes in the steel support next to them to free up the drives so you can push the darned thing around without leaving wheel skid marks.
