All else equal: Intek vs Courage single
Ric
Dont waste your money on either the Briggs Intek and Kohler Courage. Find yourself Kohler command v twin engine that's on a rider for sale.
The Command is a Great engine but there's nothing wrong with the Courage. I put just over 400hrs on my 20 single in two years and never had an issue. I can't say the same for the Intek I had though it lasted half a season before it started using more oil than gas, it was junk.
davbell22602
I heard nightmare stories about the Intek and Courage from other techs but never experienced it myself. Heard stories of Courage locking up for no warning/reason and Intek throwing rods with no warning/reason also.
jakewells
only reason i have seen either engine locked up or throw or rod is because they ran a weight to thin or ran low on oil.
Mower Doctor 78006
The older Kohler's. The commands, K model's ect are great. The kohler Courage are garbage!! They have plastic cam lobes. There durability is far less than the briggs. The intek briggs are great engines.
A_tank96
I'd have to put my money on the Kohler. I've got one with 300ish hours, runs fine. The only thing I have ever had to do was adjust the choke plate. Mine is a 2010
Carscw
My kohler courage has over 1000 hours on it. Only thing done was adjust valves. It is a 2013
Carscw
I have kohler sinks in my bathroom and they still work good after many hours.
Ean
I would go with the kohler.
I have always liked briggs until I got a cub cadet with the single cyl kohler. IMO the kohler holds it's RPMs when under a load better then the briggs. And have not had to adjust the valves as much. Only once in over 900 hours.
Me to I liked brigs until I go the experience to se one that blew up it had plenty of oil from what I could see if it were older I would get the brigs
