BlazNT Lawn Pro Aug 10, 2016 #11 If you want it to be a tool then you have the best explanation for it.
Carscw Lawn Pro Aug 10, 2016 #12 It is not a tool really not kidding it's not a tool. It is just a cover over the air passage way. You can remove it in case you need you clean the air passage way. You do not use it to clean the air passage way.
