I have a Honda H1011S mower. My question is:
How do I adjust the neutral position on the shift lever? The shift lever is out of adjustment. When you put the mower in neutral, unless you pull the lever over like you are going into reverse, the mower is still in 1st. And by the time you place the selector in 4th you're actually in 5th.
