It turns over but no spark at all. I thought at first that the single wire going to magneto was switched 12V, but then
figured out it is supposed to be grounded to kill the spark/engine, or grounded to enable the spark/engine. Which is it? I measured
2 ohms to frame ground on the yellow wire going to the magneto, with it disconnected from magneto. Also with the wire disconnected,
I measured .2 ohms to gnd. right at the magneto terminal. It seems that it must be open to gnd. to run, and because the magneto
terminal is itself grounded out, it must be bad? So magneto is no good? I would really like to have a schematic for this mower. Where
can I get one? The electrical system is a mess.
