Engine starts but won't rev out of idle. Backfiring through carburetor occasionally. I have overhauled the carb and this made no difference. Engine coughs, sputs and smokes like choke is on. Valves are set OK. New Plug. Maybe ignition coil breaking down? Maybe flywheel keyway worn causing out of time situation? HELP! Any help kindly appreciated. John
