warrenpeas
I'm trying to understand how this happened and what the function of this part is. The engine has compression and continued to run after the failure until i turned it off but was way down on power. The damage on the tip of the brass tube is obviously concerning. Im trying to decide if this is a good candidate for JB Weld because I don't understand internally what connects to that could have led to this failure.
