Fish
Take off the nut off the bottom of the carb, and let it dribble in a cup, look at the fuel for dirt, and watch and see if the dribbling slows or stops, you may have a real clogged fuel filter, or screen in the tank plugged. After it sits a bit, fuel will slowly fill the bowl a bit, enough to run a tad. Look at the nut that you took off the carb, and see if the little holes in it are plugged up.
