We don't control the economics. If you want to buy the tools to go to oversized valves and guides, or you have them already then go for it. Otherwise, why flame the messenger? I spent a good 5 years working in a very well known automotive machine shop in the racing and service fleet world in the late 1970's and early 80's so I understand clearly what is involved with loose valve guides and seating. The guides in these engines are not designed to be serviceable but they can be. The engines were designed to be throw away's when the mower, snow blower, log splitter, pump etc., wore out. The seat and valve on your engine was damaged by a carbon build up. The valve probably never fully closed and exhaust gases did their erosion. The other option is to find another 8hp engine in better shape and swap it. No home brew tool is going to fix what you are trying to do. To surface the seat beyond a hand lap you need a tight guide and the right tools. Just finding the right stone or cutter for that seat may be an expensive pain itself if you do have access to valve grinding tools.
