7hp briggs on a craftman pressure washer. Can't pull (compression)
tucolawn
  • / 7hp briggs on a craftman pressure washer. Can't pull (compression)
Hey All,
New to the forum. I have a 7 hp craftsman pressure washer with a briggs OHV engine on it. This is about 6 years old, and it has been giving me trouble for quite some time. As of late, I am simply unable to pull the engine to start. It definitely seems and sounds like a compression issue as I can pull slowly and hear and feel the air in the engine, and then move to the next stroke.
So, after lots of research, I came to the conclusion that this is likely valves being off, or a broken compression release. Since I'm not sure about the compression release, I decided to tackle the valve adjust (what an oily mess). I'm at the point where I'm trying to find 1/4 past TDC, and also adjust the valves. What is driving me crazy is this torx (or hex?) screw in the center of the valve rocker adjusters. I can not find a torx or hex that fits in there! Is it some special non-standard size? I'm somewhere between too small and too big with I think was a T10 or T15 torx. I have several torx and hex sets, and i have gone through nearly all of them. It just doesn't make sense. Never seen a bolt head this size. I also don't understand what that screw does, as I can still crank the adjuster nut up/down and even remove it.
Thanks much for any help on getting this engine running again. I really need the washer right now.
reynoldston
I have adjusted valves on Briggs engines and I can say I don't remember ever having a problem with wrench sizes. You should be able to tell the difference between hex (allen) and torx because they look a lot different. I got thinking about my torx sets which I have several sets of. All my sets go 10,15,20 etc. like you said so I don't know what you have? There is a lot of Briggs experts so maybe one of them can help you or like you said a special wrench??
pugaltitude
Hey All,
Whats your model type code?
You could try the valves but my thoughts would be a problem in the pressure washer pump before the engine. ( I could be wrong)
The centre lock screw could be a 4 mm allen key screw if the 20 torx does not fit in.
slacken the middle screw off then turn the adjuster nut which I assume is a 5/8 socket or spanner size?
Follow link and bottom of page to adjust.
Servicing Engine Valves | Briggs & Stratton
Gaps could be 0.004" - 0.006" depending on model.
reynoldston
OK I understand the wrench's now. Allen wrench sets come in two sizes MM and SAE.
Fish
btw, it is 1/4 inch past top dead cylinder, not 1/4 revolution.
tucolawn
Thanks for the quick replies!
Where can I find the model type of this briggs engine?
Also, I hear what you guys are saying about the allen/torx, but I guess at this point I need exact specs, because I've tried everything I have and I do have complete sets of both hex keys and torx. Is this an american and metric sizing with hex keys or torx that I might be missing? Pretty much everything I have is metric, as I rarely need American sizes to work on most of my stuff.
About the pressure washer pump being the culprit, I wonder if this is true. The washer had been doing that rough idling (when not operating the pump / trigger off), where it would engage and disengage constantly until the trigger was pulled and then it seemed to work OK. The reason I thought it was the engine was because of the feel of the pull. I can pull it, but if I try to pull fast , it will stop up. I then have to keep steady pressure on the cord as I can hear air moving, and then I can pull further. Also, if I take the spark plug out, the engine turns very easily. It was after I pulled the plug and was able to pull easy, that I figured it was some engine compression problem.
tucolawn
I bet that's it if it's a hex key , and not a torx. So many video show those screws being torx. I have stared at these tiny bolts in the sun and everything, and I still can't tell for sure. I think I see a sharper point which would indicate torx, but since torx just just one size range (i think), the it must be hex key.
Engine number should be either on the valve cover or a plate over the muffler. Post them and I will find you a manual. Most newer Briggs use Torx lock screws.
Fish
My money is on torx
reynoldston
My money is on torx
He was saying size between 10 and 15. now that is small for torx. Now I have several sets of torx bits and just don't see anything in them sizes? What sizes do your torx bits come in between 10 and 15? I couldn't find anything on the web also? I have never looked into this before seeing I must never needed them sizes? Now we are talking about the male torx bits not the female style sockets which use different size numbers.
