S steveleb Member Joined Oct 27, 2013 Messages 32 Oct 8, 2021 #1 I know it's an old one, but my mower will start and have a high rpms to cut the grass after 10 minutes it slows down drastically. The speed control lever is on the fastest position. Any help
H hlw49 Lawn Addict Community Leader Joined Jul 11, 2021 Messages 2,110 Location Tennessee Oct 9, 2021 #2 Does anyone know what a 7268 is.
wingless Active Member Joined May 30, 2017 Messages 81 Oct 10, 2021 #3 The Lawn Boy 7268 is a 1980 model. There is a governor controlling the throttle plate, and an air filter (that must be clean), that will all affect the rpm.
FuzzyDriver Well-Known Member Joined May 7, 2016 Messages 221 Oct 10, 2021 #4 7268's are F-engine models made from 1978 to 1982.
S steveleb Member Joined Oct 27, 2013 Messages 32 Oct 12, 2021 #5 Filter is clean and I adjusted the governor. When I started it up it ran at a higher idle and the rpms did not go down. Thanks for your help
