7268 low Idle
steveleb
I know it's an old one, but my mower will start and have a high rpms to cut the grass after 10 minutes it slows down drastically. The speed control lever is on the fastest position.
Any help
hlw49
Does anyone know what a 7268 is.
wingless
The Lawn Boy 7268 is a 1980 model.
There is a governor controlling the throttle plate, and an air filter (that must be clean), that will all affect the rpm.
FuzzyDriver
7268's are F-engine models made from 1978 to 1982.
steveleb
Filter is clean and I adjusted the governor. When I started it up it ran at a higher idle and the rpms did not go down.
Thanks for your help
