Very first thing I would do is pull apart 'weatherpack' wiring harness connector next to the mechamism. Look for white corrosion and determinne if it has snug fit when re-connecting it. Next, do likewise beneath seat where there is a 'T' connector. Loose connection in either of those can cauxe deck lift malfunction. I had to tighten those up using long nose pliers on the female connectors. One of them was culprit. Low voltage will make that thing click, but not work. Same as starter solenoid will do if battery is marginal. And I have also found corrosion inside of chassis wiring harness fuse holders too. Another thing that can cause it is a weak ground connection.
