725D issue with wheel
arizonamowers2010
I just noticed that one of the back wheels is hitting the metal frame.
Does anyone know what part I should replace, or whether I need a whole new wheel?
Scrubcadet10
Moderator
Staff member
Looks like the bushings in that wheel are toast.
need new bushings, or a new wheel if it wore into the rim it's self
7394
Clean it off thoroughly & see how much is damaged & if the rim is involved in the damage.
Rickw
Looks to me that the Yoke is bent?
7394
compare prices @ partstree.com
Rickw
Go tyo your local dealer. They usually have some parts machines out back. That is not a part that wears out
Scrubcadet10
Moderator
Staff member
That's either part of the bearing, or it looks like a snap ring or retaining ring of some sort.
Hammermechanicman
At the very least you will need 2 DP bearing assembly part #120048. Grasshoppers use an odd bearing. Clean all the grease off. Check the wheel hub and thru bolt for wear. Most likely it just needs new bearings. You need the center spacer and the thru bolt and nut. The rest is from the bearings.
