PTmowerMech
- Apr 16, 2018
- 303
- 2,207
6000 ZT
S# BBZ6027K002102249
Kohler
M# SV840-3012
S# 4003614973
Major bogging when I engage the PTO. Cleaned out the fuel lines, drained some water from the tank and the carburetor bowl. Replace the fuel pump & filter. Got it starting and running way better.
When I engaged the blades, 80's of the time, it bogs way down. 20% of the time, it's normal.
All the idlers are fine. The spindle bearings sound dry. But there's no grease fittings. So they'll have to be replaced. But I don't think that has anything to do with the engine bogging, since the spindle bearings are still loose and turn freely. They're just noisy.
Top idle RPMs is reading 3000rpm. After the engine bogs then get's back up to speed, it does fine.
Kohler
M# SV840-3012
S# 4003614973
