Yes if you have fire some of the time then it will be 3 things.......
1 a bad ground or bad contact to the coil mounting posts..... Just put a flat bastard file across both at the same time and rub gently... Not a lot just to make shiny......
2 a kill wire with bad insulation going to ground....... UNPLUG and leave unplugged..... for the meantime...
3 Yes a flywheel magnet can go bad........ Check with a 1/2 inch combo wrench about 2 inches away to see if it draws it in ETC ETC.........
And don't forget an internal short in the coil, or a dry joint in the coil or a faulty trigger module.
Have seen all 3 on cheap ebay coils customers had fitted to their mowers before they gave up & brought them to me.
