6.5 Duraforce lower seal missing?
Jabski57
Sorry for being dense, but getting old and my memory is not as good as it once was.
This is on a 10525 Lawnboy….
I took the blade off today to sharpen, and I noticed, around the shaft, there was a ton of oily grass clippings caked in there.
I hope the pictures are OK- but is there supposed to be a lower seal in that recess that sits flush with the bottom of the metal there? IMG_4313.jpegIMG_4312.jpeg
Yes there suppose to be a TC25 x 47 x 6 seal and there is also a missing snap ring.
Thanks.
Man, I’m feeling a bit foolish now because I mowed with this about half of the last season!
Much appreciated..
So I’ll clean in there as good as possible, then tap in the new seal with a socket or something? I tried to clean as much as I could for the pictures, but there was still grunge down there. I’ll clean it as good as I can before the new seal goes in.
Hell, I may as well get a new top seal while I’m at it.
I’m trying to figure out how the snap ring and seal went missing!
Thanks again!
Wait
looking on the parts diagram, it shows a retaining ring, the seal, then the snap ring. Should a retaining ring go in first? Looking at the mower, I don’t really see a retaining ring…
Edit. I missed the part where it said the retaining ring isn’t available!
awfully dry for not having a seal. Might want to check the oil level.
lol
No, that area was FULL of oil caked grass clippings! I had cleaned a lot of it out before taking the pictures.
After getting the obvious grass clippings out, it took me a while cleaning out under the lip to get everything cleaned out for the new seal.
It must have been like that for a while, because the shaft was crusty looking around where the seal will go. I took some fine emery cloth and lightly smoothed it out.
Again, not sure how the old seal and snap ring went M.I.A.🤷
StarTech, since my seal and snap ring are missing, as per the parts diagram that shows a retaining ring ABOVE all of that, should I assume that may be gone too?
Once the new seal goes back in, would it be a very snug fit, top to bottom, then the snap ring?
I don’t know how much play to expect after the new seal is in place.
Should it be very snug, and if its not, would that indicate a missing retaining that sits above it?
I have replaced several duraforce crank seals but none have ever had an extra retaining ring. But the parts diagram does show one.
Seal is # 94-5767 and retaining ring is 98-7046. From my experience the mower should not be running very good if the seal was completely gone. It would be sucking in air or
blowing out and having low compression.
Regards
  • Like
Reactions: 22R
I found a piece of pvc pipe about the same diameter of the crank seal and cut off a piece about 8 inches of so, just as long as it is longer than the crank. I lube the crank seal a little
ID and OD and tap it in place with the pvc pipe and hammer. Tapping lightly until it seats.
Regards
