xmrfacex
Hello friends,
I am in search of engine mount bolts for the 799984 engine block for a push mower. I bought the short block as a replacement and have put everything together with the exception of the engine mounting bolts that attach the engine to the pushing contraption. The old bolts twisted off while still inside of the old block rendering them useless with the exception of one bolt. Seems as if they are spot welded at the factory on the top of the bolt when they pier through the holes. I've tried to look for the bolts and washer for mounting the engine but it seems to be a ghost. Any help would be greatly appreciated.
Another problem is the engine mounting holes are not threaded for the bolts, could someone please point me in the right direction on how to do this properly.
