My 5hp Briggs and Stratton Horizontal, diaphragm carburetor, mechanical governor, will only run on full choke. It's been out of service for 20 years, and I'm trying to revive it. I couldn't get it to run at all with the original carb even after a thorough cleaning. I just installed a new, in the box, Briggs and Stratton carburetor, part number 498298 (original carb is 492611). The gas is fresh, the oil is fresh and the gas tank was cleaned. The engine started on the first pull with the new carb, but will only run on full choke. As soon as the choke shutter breaks contact with the casting wall the engine stumbles and dies. The engine is model number 132232, type 2238-01, code 88042127. I would appreciate any help toward a solution.
Thanks,
Dave
Thanks,
Dave
