natenkiki2004
- Apr 22, 2011
- 13
- 177
Hey all. I got some pretty good help the last time I was here so I thought I would come back even though this isn't a lawn mower :biggrin:
The rototiller in question is one of the old Montgomery Ward styles:
http://dl.dropbox.com/u/464376/Images/DSCF9290.JPG
I picked it up for $40. The previous owner said it last ran 2 years ago so I figured it would be worth a shot. Got it home, replaced the spark plug and put in fresh fuel and after playing with the throttle & choke, it ran. I tilled a bit with it and it seemed solid until I ran out of gas I did notice some faults with it but it doesn't seem like anything too critical. My first question before anything else, is this worthwhile? I've read a bunch of people giving high praise to these older Briggs and Stratton engines, that's the only reason why I jumped on this.
Onto the other questions, when I pull the starter cord it seems way too easy to pull and there's a hissing. I did read that it might be their "Easy-Spin" feature but I somewhat fear it might be bad compression or other more serious issues, or it might be a cause of one of the other problems below...
The tube that runs from the carb to the engine definitely has issues:
http://dl.dropbox.com/u/464376/Images/DSCF9292.JPG
^^ You can see a tear in the boot
http://dl.dropbox.com/u/464376/Images/DSCF9291.JPG
^^ There's also oil seeping from the plate (intake manifold??) which probably needs a new gasket. I have no idea where to get these parts, I did a search with the engine code and didn't really find much aside from the decoding on the B&S website. Where would/could I get replacement parts for that? Or would I have to use a gasket-in-a-tube for the plate and then borrow a new tube/boot setup from another engine? Also, the carb seems to leak right at the choke area. I sprayed starter fluid in the air intake and it just dripped right out at the choke. It doesn't look like there's a seal or anything there. Should I just ignore that?
Now for a stupid question, do these old engines have an oil filter? I can't find one and I know it doesn't take mixed gas.
Aside from that, the starter cord setup screams on and off depending on engine speed. I'll take it apart and lube it to see if that helps but I'm not entirely worried about it. The engine runs good and I was impressed with the power and performance so it can't be entirely bad Thanks in advance for any help you guys can offer.
