There were some problems with the transaxle cross member support bracket. Take a look for failure there too.
Thank so much that it can be repaired & It gives me hope that it's not going to do this ever. It's w great mower when the belt is on. (It came off 3vtimew in 1 day)Had one doing the same thing , the tension spring was stretched and no longer keeping the belt tension up, Still throwing the belt , found a missing mounting bolt on one of the hydro motors , replaced the bolt and problem went away
Thanks muchCommon issue with these mowers. Broken brackets are a big issue. There are updated brackets and cross members for these. However if you have access to a welder and a few pieces of metal you can make it so this never happens again w/o buying any kit from Hustler. One major help is adding a simple cross brace in the rear just over the muffler. Also replace bolts with grade 8.
