Southam - If the blade has taken an impact, the deck and/or cutter housing spindle could be bent. To check the spindle, remove the deck belt and spin the blade from the underside of the deck watching the blade bolt. The bolt should run concentric, if it runs in an ellipse, the spindle is likely bent. To verify the deck is straight, remove the cutter-housing and place a straightedge on the topside of the deck; check for daylight under the straightedge.  Please contact Exmark Customer Service at 800-667-5296 with your model number and serial number if you have further questions. The team is staffed with trained technicians from the factory who can help you troubleshoot your issue. Thanks.
